outputrequests
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- disp
- True if DISP is an active output-based eigenvector. Valid for hm_getvalue query only.
- disp_option
- 1 – ALL
- disp_sid
- The grid set ID.
- eke
- True if EKE is an active output-based eigenvector. Valid for hm_getvalue query only.
- eke_group
- 1 – PROP
- eke_option
- 1 – ALL
- eke_sid
- The element set ID.
- ese
- True if ESE is an active output-based eigenvector. Valid for hm_getvalue query only.
- ese_group
- 1 – PROP
- ese_option
- 1 – ALL
- ese_sid
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
Version History
2020
