dobjrefs
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- configname
- The solver name of the entity. Valid for hm_getvalue query only.
- definedentity
- True if the entity is defined, false otherwise.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- loadsteplist
- A pointer to the loadstep IDs (pointer value is loadstep ID)
- loadsteplistmax
- The number of loadstep IDs.
- name
- The name of the entity.
- negative_reference
- Reference value for a negative response.
- negative_reference_toggle
- On (1) and off (0) toggle for negative_reference. Valid for hm_getvalue query only.
- objectid
- ID of the objective function.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- positive_reference
- Reference value for a positive response.
- positive_reference_toggle
- On (1) and off (0) toggle for positive_reference. Valid for hm_getvalue query only.
- reference
- Reference flag. Valid values are:
- responseid
- The ID of the assigned response.
