configurations
Unless otherwise specified, data names are accessible in level 3 only.
- activestate
- Returns false if the entity is set inactive, true otherwise.
- attributesmax
- The number of attributes owned by this entity.
- config
- The configuration of the entity.
- configuration_entities
- The recursive list of children configuration entity IDs.
- definedentity
- True if the entity is defined, false otherwise.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- part_entities
- The recursive list of children Part Assembly and Part IDs.
- part_sets
- The recursive list of children Part Set IDs.
