groups
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- cardimage
- The name of the assigned card image.
- cardimagetype
- The type of the assigned card image.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- component
- Pointer to the component (use with the pointer - pointer1.component.name).
- config
- The configuration of the entity.
- contactsurf
- Pointer to the contactsurf.
- definedentity
- True if the entity is defined, false otherwise.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- masterallmodel
- Returns true if the master definition is all.
- masterboxmax
- The maximum global x, y and z coordinates for the master box. Valid for hm_getvalue query only.
- masterboxmin
- The minimum global x, y and z coordinates for the master box. Valid for hm_getvalue query only.
- masterboxxmax
- The maximum global x coordinate for the master box.
- masterboxxmin
- The minimum global x coordinate for the master box.
- masterboxymax
- The maximum global y coordinate for the master box.
- masterboxymin
- The minimum global y coordinate for the master box.
- masterboxzmax
- The maximum global z coordinate for the master box.
- masterboxzmin
- The minimum global z coordinate for the master box.
- mastercomponentlist
- Pointer to the master component IDs contained in the group.
- mastercomponentlistmax
- The number of master components in the group.
- mastercontactsurflist
- Pointer to the master contactsurf IDs contained in the group.
- mastercontactsurflistmax
- The number of master contactsurfs in the group.
- masterdefinition
- The method used to define the master.
- masterelementlist
- List of master elements in the group. Valid for hm_getvalue query only.
- masterentityids
- List of master entity IDs in the group. Valid for hm_getvalue query only.
- mastersetlist
- Pointer to the master set IDs contained in the group.
- mastersetlistmax
- The number of master sets in the group.
- material
- Material pointer to the material assigned to the group.
- materialid
- The ID of the material assigned to the group.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- parentcgid
- The ID of the parent contact group entity.
- set
- Pointer to sets (use with pointer - pointer1.set.name).
- slaveallmodel
- Returns true if the slave definition is all.
- slaveboxmax
- The maximum global x, y and z coordinates for the slave box. Valid for hm_getvalue query only.
- slaveboxmin
- The minimum global x, y and z coordinates for the slave box. Valid for hm_getvalue query only.
- slaveboxxmax
- The maximum global x coordinate for the slave box.
- slaveboxxmin
- The minimum global x coordinate for the slave box.
- slaveboxymax
- The maximum global y coordinate for the slave box.
- slaveboxymin
- The minimum global y coordinate for the slave box.
- slaveboxzmax
- The maximum global z coordinate for the slave box.
- slaveboxzmin
- The minimum global z coordinate for the slave box.
- slavecomponentlist
- Pointer to the slave component IDs contained in the group.
- slavecomponentlistmax
- The number of slave components in the group.
- slavecontactsurflist
- Pointer to the slave contactsurf IDs contained in the group.
- slavecontactsurflistmax
- The number of slave contactsurfs in the group.
- slavedefinition
- The method used to define the slave (integer).
- slaveelementlist
- List of slave elements in the group. Valid for hm_getvalue query only.
- slaveentityids
- List of slave entity IDs in the group. Valid for hm_getvalue query only.
- slavesetlist
- Pointer to the slave set IDs contained in the group.
- slavesetlistmax
- The number of slave sets in the group.
- type
- The solver dependent type code for the group.
- base
- The x-, y- and z-coordinates of the base node of the rigid wall.
- basenode
- Pointer to the base node of the rigid wall.
- basenodeid
- The ID of the base node of the rigid wall.
- basex
- The x-coordinate of the base node of the rigid wall.
- basey
- The y-coordinate of the base node of the rigid wall.
- basez
- The z-coordinate of the base node of the rigid wall.
- cornernode1
- The ID of the first corner node in a rigid wall finite plane or finite prism
- cornernode2
- The ID of the second corner node in a rigid wall finite plane or finite prism.
- geometrytype
- The type of geometry used to define the rigid wall.
- length
- Valid for hm_getvalue query only.
- lengthx
- The length of the rigid wall in the local x direction.
- lengthy
- The length of the rigid wall in the local y direction.
- lengthz
- The length of the rigid wall in the local z direction.
- madymoid
- The ID of the associated MADYMO entity.
- midpoint
- The x, y and z coordinates of the midpoint of the finite plane when geometrytype is 2 . Valid for hm_getvalue query only.
- midpointx
- The x coordinate of the midpoint of the finite plane when geometrytype is 2.
- midpointy
- The y coordinate of the midpoint of the finite plane when geometrytype is 2.
- midpointz
- The z coordinate of the midpoint of the finite plane when geometrytype is 2.
- motion
- The x, y and z components of the motion vector. Valid for hm_getvalue query only.
- motiondirection
- The x, y and z components of the motion vecto. Valid for hm_getvalue query only.
- motionmagnitude
- The magnitude of the motion vector.
- motiontype
- The type of motion.
- motionx
- The x component of the motion vector.
- motiony
- The y component of the motion vector.
- motionz
- The z component of the motion vector
- normal
- The x, y and z components of the normal unit vector. Valid for hm_getvalue query only.
- normalmotionangle
- The angle between the motion and the normal vector.
- normalx
- The x component of the normal unit vector.
- normaly
- The y component of the normal unit vector.
- normalz
- The z component of the normal unit vector.
- pointa
- The x, y and z coordinates of Point A on a finite plane as defined in PAMCRASH . Valid for hm_getvalue query only.
- pointax
- The x coordinate of Point A on a finite plane as defined in PAMCRASH.
- pointay
- The y coordinate of Point A on a finite plane as defined in PAMCRASH.
- pointaz
- The z coordinate of Point A on a finite plane as defined in PAMCRASH.
- radius
- The radius of a cylinder or spherical rigid wall.
- radiusnode
- Pointer to the radius node assigned to a cylinder or spherical rigid wall.
- xaxis
- The x, y and z components of the local x axis unit vector. Valid for hm_getvalue query only.
- xaxisx
- The x component of the local x axis unit vector.
- xaxisy
- The y component of the local x axis unit vector.
- xaxisz
- The z component of the local x axis unit vector.
- yaxis
- The x, y and z components of the local y axis unit vector. Valid for hm_getvalue query only.
- yaxisx
- The x component of the local y axis unit vector.
- yaxisy
- The y component of the local y axis unit vector.
- yaxisz
- The z component of the local y axis unit vector.
Version History
2020 - Added new data names color_rgb and parentcgid.
