ddvals
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- configname
- The solver name of the entity. Valid for hm_getvalue query only.
- definedentity
- True if the entity is defined, false otherwise.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- rangeindex
- A pointer to the discrete value increments (pointer value is discrete value increment).
- rangeindexmax
- The number of discrete values.
- values
- A pointer to the discrete values (pointer value is discrete value).
- valuesmax
