tags
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- body
- The last part of the tag name, following the colon.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- description
- The text description of the tag.
- entity
- The ID of the entity the tag is attached to.
- entityid
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- label
- The first part of the tag name, proceeding the colon.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- type
- The type of entity the tag is attached to.
Version History
2020 - Added new data name color_rgb.
