constrainedrigidbodies
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- id
- The ID of the entity.
- iflag
- 0 - Inertia properties of the Part ID are not defined in PART_INTERTIA.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- mastercompid
- The ID of the master rigid body.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- slavecompids
- The IDs of the slave rigid bodies.
Version History
2020 - Added new data name color_rgb.
