CELAS4
Bulk Data Entry Defines a scalar spring element that is connected only to scalar points without reference to a property entry.
CELAS4 | EID | K | S1 | S2 | GE | S |
CELAS4 | 42 | 6.2-3 | 2 |
EID | Unique element
K | Stiffness of the scalar
spring. No default (Real) |
S1, S2 | Scalar point
identification numbers. S1 or S2, but not both, may be blank or zero indicating a constrained coordinate. Default = 0 (Integer ≥ 0; S1 ≠ S2) |
GE | Damping
coefficient. GE is ignored in transient analysis, if PARAM, W4 is not specified. Default = 0.0 (Real) |
S | Stress
coefficient. Default = 0.0 (Real) |
- This single entry completely defines the element since no material or geometric properties are required.
- Only one scalar spring element may be defined on a single entry.
- A scalar point specified on this entry does not need to be defined on a SPOINT Bulk Data Entry.
The element force of a spring is calculated from the equation:
(1) Where, is the stiffness coefficient for the scalar element and is the displacement of the first degree-of-freedom listed on the CELAS entry.Element stresses are calculated from the equation:(2) Where, is the stress coefficient as defined above. - This card is represented as a spring or mass element in HyperMesh.
