PBARL
Bulk Data Entry Defines the properties of a simple beam (bar) by cross-sectional dimensions, which is used to create bar elements via the CBAR entry.
PBARL | PID | MID | GROUP | TYPE/ NAME |
ND | ||||
DIM1 | DIM2 | DIM3 | DIM4 | DIM5 | DIM6 | DIM7 | DIM8 | ||
DIM9 | etc | NSM |
PBARL | 12 | 7 | BOX | ||||||
10. | 6. | .5 | .5 |
PID | Unique simple beam property
identification.
No default (Integer > 0 or <String>) |
MID | Material identification. 1
2
GROUP | Indicates if an arbitrary beam section
definition is to be used. Refer to Arbitrary Beam Section Definition in the User Guide.
If the value of this field is HYPRBEAM, the following field is
NAME; otherwise it is TYPE. Default = blank (blank or HYPRBEAM) |
TYPE | Cross-section type. When
GROUP field is blank, this field is TYPE.
No default |
NAME | Name of arbitrary beam section
definition. Refer to Arbitrary Beam Section Definition in the
User Guide. When the value of GROUP is
HYPRBEAM, this field is NAME. No default (Character string) |
ND | Number of dimensions used to specify the
Cross-section shape. This is required when the value of the GROUP
field is HYPRBEAM. ND represents the total number
of dimensions used to define an Arbitrary Beam Section. Default = blank |
DIMi | Cross-sectional dimensions. No default (Real > 0.0) |
NSM | Nonstructural mass per unit length.
NSM is specified after the last
DIMi. Default = 0.0 (Real) |
- For structural problems, MID may reference only a MAT1 material entry. For heat transfer problems, MID may reference only a MAT4 material entry.
- String based labels allow for easier visual identification of properties, including when being referenced by other cards. (For example, the PID field of elements). For more details, refer to String Label Based Input File in the Bulk Data Input File.
- The cross-sectional properties, shear flexibility
factors, and stress recovery points (C, D,
E, and F) are computed using the
TYPE and DIMi as shown below. The origin of the
element coordinate system is centered at the shear center of the cross-section oriented as
shown. The PBARL does not account for offsets between the neutral axis
and the shear center. Therefore, the CHAN cross-sections may produce
incorrect results. The PBEAML entry is
recommended.
- The torsional coefficient (J) is approximate for non-regular hexagons (TYPE = HEXA).
- This card is represented as a property in HyperMesh.
