PFAT
Bulk Data Entry Defines element properties for fatigue analysis.
PFAT ID Layer Finish Treatment Kf CRTDIST
ID Each PFAT card must have a unique ID. This ID may be referenced from a FATDEF definition.
No default (Integer > 0)
Layer Region Layer for shell elements. 1
0 (Default)
Worst
1
Top
2
Bottom
Finish Material Surface Finish, a result of manufacturing process. 3
NONE (Default)
POLISH
GROUND
MACHINE
HOTROLL
FORGE
Or any float value between 0.0 and 1.0.
When it is a float value, it will be used to modify the fatigue limit by multiplied with the original fatigue limit.
Treatment Material Surface Treatment for Material S-N Curve, a process used to enhance the fatigue life. 3
NONE (Default)
NITRIDED
SHOTPEEN
COLDROLL
Or any float value greater than 0.0.
Kf Fatigue strength reduction factor. 2 3
Default = 1.0 (Real ≥ 1.0)
CRTDIST Critical Distance defines the location from the shell surface where the stresses are evaluated. 4
AUTO
OptiStruct calculates the critical distance automatically depending on the model.
Not supported for Factor of Safety (FOS) run.
Real > 0.0
The user-defined critical distance is used.
Blank (Default)
(Real)
  1. If shell elements are used, it is necessary to specify the appropriate layer or Surface of results to use Top or Bottom. Worst is the worst result of Top and Bottom (the one with larger damage).
  2. Fatigue strength reduction factor takes into account the effect of notch effects, size effects, and loading type influence.(1)
    K f = C n o t c h C s i z e C l o a d i n g
    Where, C n o t c h , C s i z e , and C l o a d i n g are correction factors for notch effect, size effect, and loading type influence.
  3. Finish, Treatment and K f are ignored in FOS analysis (TYPE=FOS on FATPARM).
  4. The Critical Distance field is only supported for shell elements. Critical distance is not applied to surface stress of solid elements as surface stress is based on pure membrane stress. If this field is blank, there is no critical distance effect. Critical distance is only supported for Static and Transient analysis based Fatigue, it is not currently supported for Random Response Fatigue Analysis.
    The Critical Distance field is a way to consider stress gradient effect. The stress evaluation point is at CRTDIST/2 distance below the surface.
    For AUTO option, the critical distance is calculated as:(2)
    C R T D I S T = ( ( 7.0 × 10 4 ) ( E / ( F L ) ) ) 1.92 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4qaiaadk facaWGubGaamiraiaadMeacaWGtbGaamivaiabg2da9maabmaabaWa aeWaaeaacaaI3aGaaiOlaiaaicdacqGHxdaTcaaIXaGaaGimamaaCa aaleqabaGaeyOeI0IaaGinaaaaaOGaayjkaiaawMcaamaabmaabaWa aSGbaeaacaWGfbaabaWaaeWaaeaacaWGgbGaamitaaGaayjkaiaawM caaaaaaiaawIcacaGLPaaaaiaawIcacaGLPaaadaahaaWcbeqaaiaa igdacaGGUaGaaGyoaiaaikdaaaaaaa@5011@
    Where,
    E MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyraaaa@36C1@
    Young’s modulus of the material
    F L MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraiaadY eaaaa@3792@
    Fatigue limit defined on the corresponding MATFAT Bulk Data Entry
    The units of CRTDIST in Equation 2 is mm. If you define CRTDIST manually, then OptiStruct will directly use it without any unit conversion.
    This approach is based on Atzori, Meneghetti and Susmel, "Material fatigue properties for assessing mechanical components weakened by notches and defects" Fatigue and fracture of Engineering Materials and Structures, Vol. 28, 83-97, 2005.
  5. This card is represented as a load collector in HyperMesh.
