ERPPNL
Bulk Data Entry Defines one or more sets of elements as panels for equivalent radiated power output for a frequency response analysis of a coupled fluid-structural model.
ERPPNL | NAME1 | SID1 | NAME2 | SID2 | NAME3 | SID3 | NAME4 | SID4 | |
NAME5 | SID5 | etc |
NAME# | Panel label. No default (Character string) |
SID# | Set
identification number for a set of elements. No default (Integer > 0) |
