Bulk Data Entry Defines a set of grids or elements.
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
SET3 |
SID |
TYPE |
ID1 |
ID2 |
ID3 |
ID4 |
ID5 |
ID6 |
ID7 |
ID8 |
etc. |
Example 1
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
SET3 |
1 |
PROP |
11 |
12 |
13 |
15 |
18 |
21 |
Alternate Format and Example
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
SET3 |
SID |
TYPE |
ID1 |
"THRU" |
ID2 |
SET3 |
33 |
GRID |
20 |
THRU |
60 |
Field |
Contents |
SI Unit Example |
SID |
Unique identification number. (Integer > 0)
TYPE |
Set
type (Character)
- GRID
- Grid points
- ELEM
- Elements
- PROP
- Creates a list of elements associated with the property ID's listed.
IDi |
Identifiers of grid points, elements, or
properties. (Integer > 0)
- All set ID's must be unique for all Bulk Data
SET, SET1,
SET3, and solution control SET data.
- The use of keywords THRU,
ENDTHRU, and EXCEPT are allowed.
- This card is represented as a set in HyperMesh.
