MATX65
Bulk Data Entry Defines additional material properties for tabulated strain rate dependent elastic-plastic material for geometric nonlinear analysis.
MATX65 | MID | EPSMAX | FSMOOTH | FCUT | NLOAD |
TIDL | TIDU | EPSR | FSCAL |
MAT1 | 91 | 60.4 | 0.33 | 2.70E-06 | |||||
MATX65 | 91 | 2.70E-06 | 1 | ||||||
1 | 2 |
MID | Material ID of the
associated MAT1. 1 No default (Integer > 0) |
EPSMAX | Failure plastic strain
max. (Real > 0) |
FSMOOTH | Strain rate filtering
flag.
FCUT | Cutoff frequency for
strain rate filtering. Default = 1.E30 (Real ≥ 0) |
NLOAD | Number of
loading/unloading stress-strain function pairs. Default = 0 (Integer > 0) |
TIDL | Identification number
of TABLES1 entry that defines the loading
stress-strain function. (Integer > 0) |
TIDU | Identification number
of TABLES1 entry that defines the unloading
EPSR | Strain rate. Default = 1.0 (Real) |
FSCAL | Scale factor for
stress. Default = 1.0 (Real) |
- The material identification number must be that of an existing MAT1 Bulk Data Entry. Only one MATXi material extension can be associated with a particular MAT1.
- MATX65 is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS = EXPDYN. It is ignored for all other subcases.
- The material law is defined by pairs of
stress functions for loading and unloading at a constant strain rate. For each
strain rate, the yield stress is defined by the intersection between loading and
unloading curves. Unloading follows unloading curve shifted by plastic strain value.
Strain rates are interpolated using input values. In the elastic range, stress
smaller than the yield value, the material behavior is elastic with hysteresis. It
is limited by loading and unloading curves.
The Young's modulus must be greater than the maximum function slopes, and is used to follow loading and unloading paths between limiting curves.
- This card is represented as a material in HyperMesh.
