PCNTX24
Bulk Data Entry Defines properties TYPE24 of a CONTACT interface for geometric nonlinear analysis.
PCNTX24 | PID | ||||||||
ISTF | |||||||||
GAPMAXs | GAPMAXm | ||||||||
STMIN | STMAX | IGAP0 | IPEN0 | IPENMAX | IPENMIN | ||||
STFAC | FRIC | TSTART | TEND | ||||||
IBC | INACTI | VISS | |||||||
IFRIC | IFILTR | FFAC | SENSID | ||||||
FRICDAT | C1 | C2 | C3 | C4 | C5 | C6 |
PCONT | 34 | ||||||||
PCNTX24 | 34 |
PID | Property identification number of the
corresponding PCONT entry. No default (Integer > 0) |
ISTF | Stiffness definition flag. 5
Default as defined by CONTPRM (Integer = 0, ..., 5) |
GAPMAXs | Slave maximum
gaps. (Real) |
GAPMAXm | Master maximum
gaps. (Real) |
STMIN | Minimum stiffness (Only with
ISTF > 1). Default as defined by CONTPRM (Real ≥ 0) |
STMAX | Maximum stiffness (Only with
IGAP0 | Gap modification flag for slave shell
nodes on the free edges.
(Integer) |
IPEN0 | Initial penetration detection flag.
(Integer) |
IPENMAX | Maximum initial penetration:
Penetration higher than this value will not be taken into
account. (Real) |
IPENMIN | Minimum initial penetration:
Penetration higher than this value will be taken into
account. (Real) |
STFAC | Interface stiffness scale
factor. Default as defined by CONTPRM (Real ≥ 0) |
FRIC | Coulomb friction. Default as defined by CONTPRM (Real ≥ 0) |
TSTART | Start time Default = 0.0 (Real ≥ 0) |
TEND | Time for temporary
deactivation. Default = 1030 (Real ≥ 0) |
IBC | Flag for deactivation of boundary
conditions at impact applied to the slave grid set. Default as defined by CONTPRM (Character = X, Y, Z, XY, XZ, YZ, or XYZ) |
INACTI | Handling of initial penetrations flag.
Default as defined by CONTPRM (Integer = 0, 1, -1, or 5) |
VISS | Critical damping coefficient on
interface stiffness. Default as defined by CONTPRM (Real ≥ 0) |
IFRIC | Friction formulation flag. 8
Default as defined by CONTPRM (Character) |
IFILTR | Friction filtering flag. 9
FFAC | Friction filtering factor. Default as defined by CONTPRM |
SENSID | Sensor identifier to Activate/Deactivate the interface 12 No default (Integer) If a sensor identifier is defined, the activation/deactivation of interface is based on the sensor and not on TSTART or TSTOP. |
FRICDAT | Indicates that additional information for IFRIC will follow. Only available when IFRIC = GEN, DARM or REN. | |
C1, C2, C3, C4, C5, C6 | Coefficients to define variable
friction coefficient in IFRIC = GEN, DARM, or
REN. Default as defined by CONTPRM (Real ≥ 0) |
- The property identification number must be that of an existing PCONT Bulk Data Entry. Only one PCNTX24 property extension can be associated with a particular PCONT.
- PCNTX24 is only supported for geometric nonlinear explicit dynamic analysis subcase defined by ANALYSIS = EXPDYN. It is ignored for all other subcases.
- If FRIC is not explicitly defined on the PCONTX/PCNTX# entries, the MU1 value on the CONTACT or PCONT entry is used for FRIC in the /INTER entries for Geometric Nonlinear Analysis. Otherwise, FRIC on PCONTX/PCNTX# overwrites the MU1 value on CONTACT/PCONT.
- In
implicit analysis, different contact formulations
are used for contact where slave and master set do
not overlap and where they overlap
(self-contact).
In the case of self-contact, the gap cannot be zero and a constant gap is used. For small initial gaps, the convergence will be more stable and faster if GAP is larger than the initial gap.
In implicit analysis, sometimes a stiffness with scaling factor reduction (for example, STFAC = 0.01) or reduction in impacted thickness (if rigid one) might reduce unbalanced forces and improve convergence, particularly in shell structures under bending where the effective stiffness is much lower than membrane stiffness; but it should be noted that too low of a value could also lead to divergence.
- If
ISTF
≠ 1, the interface stiffness K is computed from the master segment stiffness Km and/or the
slave segment stiffness Ks.
The master stiffness is computed from Km = STFAC * B * S * S/V for solids, Km = 0.5 * STFAC * E * t for shells.
The slave stiffness is an equivalent nodal stiffness computed as Ks = STFAC * B * V-3 for solids, Ks = 0.5 * STFAC* E * t for shells.
In these equations, B is the Bulk Modulus, S is the segment area, and V is the volume of a solid. There is no limitation to the value of stiffness factor (but a value larger than 1.0 can reduce the initial time step).
The interface stiffness is K = max (STMIN, min (STMAX, K1)) with:- ISTF = 0, K1 = Km
- ISTF = 2, K1 = 0.5 * (Km + Ks)
- ISTF = 3, K1 = max (Km, Ks)
- ISTF = 4, K1 = min (Km, Ks)
- ISTF = 5, K1 = Km * Ks / (Km + Ks)
- The
gap is computed automatically (similar with IGAP = VAR
on PCNTX7) for each impact as gs + gm;with:
- gm - master element gap, with:
gm = t/2, t: thickness of the master element for shell elements.
gm = 0 for solid elements.
- gs - slave node gap:
gs = 0 if the slave node is not connected to any element or is only connected to solid or spring elements.
gs = t/2, t - largest thickness of the shell elements connected to the slave node.
gs = 1/2✓S for truss and beam elements, with S being the cross section of the element.
gm and gs are limited separately by GAPMAXm and GAPMAXs before the gap computation.
- The coefficients C1 - C6 are used to define a variable friction coefficient .
- IFRIC
defines the friction model.
IFRIC = COUL - Coulomb friction with FT ≤ FRIC * FN.
For IFRIC > 0 the friction coefficient is set by a function ( ).
Where, p is the pressure of the normal force on the master segment and V is the tangential velocity of the slave node.
The following formulations are available:- IFRIC = GEN - Generalized viscous friction law
(1) - IFRIC = DARM - Darmstad law
(2) - IFRIC = REN - Renard law
0 ≤ V ≤ C5 C5 ≤ V ≤ C6 C6 ≤ V Where,(3) - The first critical velocity Vcr1 must not be 0 (C5 ≠ 0). It also must be lower than the second critical velocity Vcr2 (C5 < C6).
- The static friction coefficient C1 and the dynamic friction coefficient C2, must be lower than or equal to the maximum friction C3 (C1 ≤ C3 and C2 ≤ C3).
- The minimum friction coefficient C4, must be lower than or equal to the static friction coefficient C1 and the dynamic friction coefficient C2 (C4 ≤ C1 and C4 ≤ C2).
- IFILTR
defines the method for computing the friction filtering coefficient. If IFILTR ≠
NO, the tangential friction forces are smoothed using a
filter:
FT = α * F'T + (1 - α) * F'T-1
Where,- FT
- Tangential force
- F'T
- Tangential force at time t
- F'T-1
- Tangential force at time t-1
- α
- Filtering coefficient
IFILTR = SIMP - α = FFAC
IFILTR = PER - α = 2π dt/FFAC, where dt/T = FFAC, T is the filtering period
IFILTR = CUTF - α = 2π * FFAC * dt, where FFAC is the cutting frequency
- IFORM
selects two types of contact friction penalty formulation.
The viscous (total) formulation (IFORM = VISC) computes an adhesive force as:
Fadh = VISF * ✓(2KM) * VT
FT = min ( FN, Fadh)
The stiffness (incremental) formulation (IFORM = STIFF) computes an adhesive force as:
Fadh = FTold + FT
FT = K * VT * dt
FTnew = min ( FN, Fadh)
- When SENSID is defined for activation/deactivation of the interface, TSTART and TSTOP are not taken into account.
- When the contact type is the symmetric surface to surface, the output normal contact forces in TH file are correctly calculated if the two surfaces are well separated.
- For implicit test: Interface TYPE24 is now only available with SMP. The default of ISTF will be set to 4. The default INACTI will be set to -1.
- This card is represented as an extension to a PCONT property in HyperMesh.
