DVPREL1
Bulk Data Entry Relates Design Variables to Analysis Model Properties
DVPREL1 | ID | TYPE | PID | PNAME/ FID |
C0 | ||||
DVID1 | COEF1 | DVID2 | COEF2 | etc. |
Example 1
DVPREL1 | 88 | PSHELL | 1 | 4 | 0.0 | ||||
5 | 1. | ||||||||
DESVAR | 5 | 5.00 | 1.50 | 9.90 |
Example 2
DVPREL1 | 88 | PSHELL | 1 | T | 0.0 | ||||
5 | 1. | ||||||||
Definition
ID | Relationship identification number. ID must be
unique with respect to other
DVPREL1 cards. No default (Integer > 0) |
TYPE | Property type to be related (see DVPREL - Types). No default (Character) |
PID | Property identification number. When
PTYPE is
PCOMPG, G#
may be used where # is the
GPLYID. When
PTYPE is
PCOMPP, P# may be used where #
is the PLY ID. 2 No default (Integer > 0) |
PNAME/FID | Property name, such as "A" or "T" (as in the documentation of the property cards),
or field number in property card (see Table 1). For the PSHELL property
12I/T3, only the filed number (6) is allowed. For PBARL and
PBEAML only property names are allowed, as different sections
use different fields. No default (Character or Integer > 0) |
C0 | Constant in relationship equation. Default = 0.0 (Real) |
DVIDi | DESVAR ID. No default (Integer > 0) |
COEFi | Coefficient in relationship equation. Default = 1.0 (Real) |
- TYPE cannot be PSOLID.
- When TYPE is PCOMPG, either global plies or
property specific plies may be selected.
To select property specific plies, the format is similar to that used for other property types where the property identification number of the PCOMPG is entered in the PID field and then either PNAME or FID is used to identify the value to be related. In this scenario, only the property with an ID given in the PID field is affected.
To select global plies, G# is entered in the PID field where, # is the GPLYID of a global ply. In this instance, FID is not applicable so T or THETA is used in the PNAME field to relate either the thickness or orientation, respectively. In this scenario, all plies that use the given GPLYID are affected.
When TYPE is PCOMPP, P# is entered in the PID field where # is the ID of a PLY entity. In this instance, FID is not applicable so T or THETA is used in the PNAME field to relate either the thickness or orientation, respectively.
- PBEAML definitions with more than one section definition may not be referenced by a DVPREL1.
- Properties of PBARL/PBEAML have to be controlled through DIMs (cannot be controlled directly), with the exception of NSM.
- When TYPE is
PBARL or
PBEAML, users should pay close
attention to the variable ranges to avoid invalid
dimensions. For example, the inner radius of a
tube cross-section cannot exceed the outer radius.
It is necessary to prevent combinations of
dimensions from taking on values that are
physically meaningless. Some constraints are
applied automatically on section dimensions. The
table below summarizes these constraints.
Constraints are satisfied when they are < 0.0.
Table 1. Section Type Constraint TUBE DIM2 - DIM1 I DIM4 - DIM2 DIM4 - DIM3 DIM5 + DIM6 - DIM1 CHAN 2 * DIM4 - DIM2 DIM3 - DIM1 T DIM3 - DIM2 DIM4 - DIM1 BOX DIM4 - DIM1 DIM3 - DIM2 CROSS DIM4 - DIM3 H DIM4 - DIM3 T1 DIM4 - DIM1 I1 DIM3 - DIM4 CHAN1 DIM3 - DIM4 Z DIM3 - DIM4 CHAN2 DIM2 - DIM3 2 • DIM1 - DIM4 T2 DIM4 - DIM1 DIM3 - DIM2 BOX1 DIM4 + DIM3 - DIM2 DIM5 + DIM6 - DIM1 HEXA 2 * DIM1 - DIM2 HAT 2 * DIM2 - DIM1 2 * DIM2 - DIM3 L DIM3 - DIM2 DIM4 - DIM1 HAT1 DIM3 - DIM1 2 * DIM4 - DIM2 2 * DIM4 + DIM5 - DIM2 - In the PCOMP property, the damping coefficient, GE is a designable value and can be referenced in the PNAME/FID field.
- This card is represented as an optimization design variable in HyperMesh.
