PSOLIDX
Bulk Data Entry Defines additional SOLID properties for geometric nonlinear analysis.
PSOLIDX | PID | ISOLID | NIP | ISMSTR | ICPRE | IFRAME | DN | QS | |
QB | HV | DTMIN | LAMBDAV | MUV | IHKT |
PSOLID | 77 | 7 | |||||||
PSOLIDX | 77 | 24 |
PID | Property identification number of the
associated PSOLID. 1 No default (Integer > 0) |
ISOLID | Solid elements formulation flag.
Default as defined by XSOLPRM (Integer) |
NIP | Number of integration points (ISOLID=14 and 16 only). Default as defined by XSOLPRM (Integer = ijk) 2 ≤ i, j, k ≤ 9 for ISOLID =14 2 ≤ i, k ≤ 3, 2 ≤ j ≤ 9 for ISOLID =16 where:
ISMSTR | Small strain formulation flag (ISOLID=1, 2, 14, and
24 only).
ICPRE | Reduced pressure integration flag
(VAR=14, 17, and
24 only). Default = OFF for ISOLID=14, 24, ON for ISOLID=17 (ON, OFF, or VAR) VAR - Variable state between ICPRE=ON and ICPRE=OFF in function of plasticity state. Only available for elasto-plastic material law. |
IFRAME | Element coordinate system formulation
flag (ISOLID=1, 2, 12,
17 only). Default as defined by XSOLPRM (ON or OFF) |
DN | Numerical damping for stabilization (ISOLID=24 only). Default = 0.1 (Real) |
QS | Quadratic bulk viscosity. Default = 1.1 (Real) |
QB | Linear bulk viscosity. Default = 0.05 (Real) |
HV | Hourglass viscosity coefficient. Is not
active with 8 point integration. Default = 0.1 (0.0 ≤ Real ≤ 0.15) |
DTMIN | Minimum time step. Default = 0.0 (Real) |
LAMBDAV | Numerical Navier Stokes viscosity
No default (Real) |
MUV | Numerical Navier Stokes viscosity
No default (Real) |
IHKT | Hourglass tangent modulus flag (ISOLID=24 only)
- The property identification number must be that of an existing PSOLID Bulk Data Entry. Only one PSOLIDX property extension can be associated with a particular PSOLID.
- PSOLIDX is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS=EXPDYN. It is ignored for all other subcases.
- The ISOLID flag is not used with CTETRA elements. For these elements with four and ten nodes, the number of integration points is fixed at one and four, respectively.
- For fully integrated solids (ISOLID=12), the deviatoric behavior is computed using 8 Gauss points; bulk behavior is under-integrated to avoid element locking. It is currently compatible with material MAT1, MATS1, MATX33, and MATX36.
- With the small strain option (ISMSTR), strain and stress is engineering strain and stress. Otherwise, it is true strain and stress.
- In time history and animation files, the stress tensor is written in the co-rotational frame.
- Fully integrated elements (ISOLID=12) only uses full geometric non-linearity (corresponds to ISMSTR=4). Time step limit has no effect.
- The time step control XSTEP, TYPEi=SOLID, TSCi=CST only works on elements with ISMSTR=2.
- Co-rotational formulation: For ISOLID=1, 2, 12 and IFRAME=ON, the stress tensor is computed in a co-rotational coordinate system. This formulation is more accurate if large rotations are involved. It comes at the expense of higher computation cost. It is recommended in case of elastic or visco-elastic problems with important shear deformations. The co-rotational formulation is compatible with 8 node solids.
- HA8 (ISOLID=14) elements: this element uses a locking-free general solid formulation, co-rotational. The number of Gauss points is defined by NIP flag: for example, combined with NIP=222 gives an 8 Gauss integration point element, similar to ISOLID=12. The HA8 formulation is compatible with all material laws. Under-integration for pressure should be used (ICPRE=ON in case of elastic or visco-elastic material; ICPRE=VAR in case of elasto-plastic material).
- H8C (ISOLID=17) elements: Their brick deviatoric behavior is the same as ISOLID=12, but the bulk behavior can be chosen with ICPRE, and is compatible with all solid type material laws. ICPRE=VAR is the default value and ICPRE=OFF will not reduce pressure integration.
- The hourglass formulation is viscous for ISOLID=0, 1, and 2.
- It is recommended to use IHKT=2 (ISOLID=24) and Lagrange type total strain, ISMSTR=10 for foam or rubber materials, like MATX42 and MATX82. For elasto-plastic type material, IHKT=2 will have a tighter yield stress criterion for an hourglass stress computation.
- This card is represented as an extension to a PSOLID property in HyperMesh.
