SECT
Bulk Data Entry Defines a section for force output in geometric nonlinear analysis.
SECT | SCID | G0 | G1 | G2 | GRSET | ELSET | IFRAME | CID | |
DT |
SECT | 2 | 234 | 665 | 723 | 3 | 4 |
SCID | Section identification number. No default (Integer > 0) |
G0, G1, G2 | Grid points defining the local axes of
the section. G0 and G1 define the local x-axis
while G0, G1, and G3 define
the local xy-plane. No default (Integer > 0) |
GRSET | Grid set identification number. No default (Integer > 0) |
ELSET | Element set ID. Only sets of
SOLID, SHELL, ROD,
BAR, and BEAM elements can be
used. (Integer > 0) |
IFRAME | Flag for computing the center of the
output coordinate system. The local system is defined by G0,
G1, and G2.
(Integer) |
CID | Moving coordinate system identifier for
automatic definition of a section. Only CORD1R and
CORD3R can be selected. 4 Default = 0 (Integer ≥ 0) |
DT | Time step for saving the data. Default = DTTH defined on XSOM (Real > 0) |
- SECT output must be selected for time history output with XHIST. It is only available for geometric nonlinear analysis subcases which are defined by an ANALYSIS=EXPDYN subcase entry.
- Moments are computed with respect to the section center defined by the parameter IFRAME and expressed in the local section frame.
- Normal force is the component normal to the XY plane of the section. The tangential force is the component in the plane of the section.
- For CID > 0:
- G0, G1, G2 blank - the local system of the section is built from the grid points defining the CORD1R or CORD3R.
- The element set is created automatically from the elements intersected by the xy-plane of CID.
- The grid set is created automatically from the grid points of the intersected elements on the positive z-axis defined by the xy-plane plane of the frame.
- This card is represented as an interface in HyperMesh.
