PBUSHFX
Bulk Data Entry Defines the various nominal property values for a generalized spring-damper-mass structural element. This property is not affected by translational and rotational stiffness limits specified using PARAM, BUSHSTIF.
PBUSHFX | PID | K | K1 | K2 | K3 | K4 | K5 | K6 | |
B | B1 | B2 | B3 | B4 | B5 | B6 | |||
GE | GE1 | GE2 | GE3 | GE4 | GE5 | GE6 | |||
M | M1 | M2 | M3 | M4 | M5 | M6 |
Example 1
PBUSHFX | 35 | K | 4.35 | 2.4 | RIGID | 3.1 | |||
GE | 0.02 |
Example 2
PBUSHFX | 35 | B | 4.35 | ||||||
M | 1.2 | 7.1 |
PID | Property identification number. No default (Integer > 0) |
K | Flag
indicating that the next 1 to 6 fields are
stiffness values. No default (Character) |
Ki | Nominal stiffness values in directions 1 through 6. 3
5
Default = 0.0 (Real or RIGID) |
B | Flag
force-per-velocity damping. No default (Character) |
Bi | Nominal damping coefficients in directions 1
through 6 in units of force per unit
velocity. Default = 0.0 (Real) |
GE | Flag
indicating that the next 1 to 6 fields are the
structural damping constants. No default (Character) |
GEi | Nominal structural damping constants in
directions 1 through 6. GEi is ignored in transient analysis, if PARAM, W4 is not specified. 35 Default = 0.0 (Real) |
M | Flag indicating that the next 1 to 6 fields are directional masses. | |
Mi | Nominal mass values in directions 1 through 6.
The Mi fields do not contribute
to mass and inertia properties. Their
contributions to gravity and/or centrifugal
loading are also not included. Default = 0.0 (Real) |
- All generalized spring-damper-mass property entries must have unique ID numbers.
- The K, B, GE, and M lines may be specified in any order.
- Ki,
Bi, GEi, or
Mi may be made frequency
dependent for both direct and modal frequency
response by use of the PBUSHT
entry.
The nominal values are used for all analysis types except frequency response. For modal frequency response, the normal modes are computed using the nominal Ki values. The frequency-dependent values are used at every excitation frequency.
- To obtain the damping coefficient GE, multiply the critical damping ratio by 2.0.
- For backward compatibility with Nastran, if ONLY GE1 is specified on a PBUSH entry and GEi, i = 2 to 6 are blank on that PBUSH entry, then a single structural damping is assumed and applied to all Ki of that PBUSH. If a PBUSH entry has a GEi, i = 2 to 6 specified, then the GEi fields are considered variable for that PBUSH entry.
- The keyword RIGID may be used in place of a stiffness value for Ki entries. When RIGID is defined, a very high relative stiffness (relative to the surrounding structure) is selected for that degree-of-freedom simulating a rigid connection.
- Rotational stiffness values are input based on rotations defined in Radians.
- This card is represented as a property in HyperMesh.
