MATT8
Bulk Data Entry Specifies temperature-dependent material properties on MAT8 entry fields via TABLEMi or TABLEG entry.
MATT8 | MID | T(E1) | T(E2) | T(NU12) | T(G12) | T(G1Z) | T(G2Z) | T(RHO) | |
T(A1) | T(A2) | T(Xt) | T(Xc) | T(Yt) | T(Yc) | T(S) | |||
T(GE) | T(F12) |
MATT8 | 17 | 32 | 15 | ||||||
15 | 52 |
MID | Material property identification number
that matches the identification number on MAT1 entry. (Integer > 0) |
T(E1) | Identification number of a
TABLEMi or TABLEG entry for the Young's
modulus 1. (Integer ≥ 0 or blank) |
T(E2) | Identification number of a
modulus 2. (Integer ≥ 0 or blank) |
T(NU12) | Identification number of a
TABLEMi or TABLEG entry for the Poisson's
ratio 12. (Integer ≥ 0 or blank) |
T(G12) | Identification number of a
TABLEMi or TABLEGentry for shear modulus
T(G1Z) | Identification number of a
TABLEMi or TABLEG entry for transverse shear
modulus 1Z. (Integer > 0 or blank) |
T(G2Z) | Identification number of a
modulus 2Z. (Integer ≥ 0 or blank) |
T(RHO) | Identification number of a
TABLEMi or TABLEG entry for mass
density. (Integer ≥ 0 or blank) |
T(A1) | Identification number of a
TABLEMi or TABLEG entry for the thermal
expansion coefficient 1. 3 (Integer or blank) |
T(A2) | Identification number of a
expansion coefficient 2. (Integer or blank) |
T(Xt) | Identification number of a
TABLEMi or TABLEG entry for the tension
stress/strain limit 1. (Integer ≥ 0 or blank) |
T(Xc) | Identification number of a
TABLEMi or TABLEG entry for compression
T(Yt) | Identification number of a
TABLEMi or TABLEG entry for tension
stress/strain limit 2. (Integer ≥ 0 or blank) |
T(Yc) | Identification number of a
T(S) | Identification number of a
TABLEMi or TABLEG entry for shear
stress/strain limit. (Integer ≥ 0 or blank) |
T(GE) | Identification number of a
TABLEMi or TABLEG entry for structural
damping coefficient. (Integer ≥ 0 or blank) |
T(F12) | Identification number of a
TABLEMi or TABLEG entry for Tsai-Wu
interaction term. (Integer ≥ 0 or blank) |
- Fields 3, 4, and so on of this entry correspond, field-by-field, to fields 3, 4, and so on of the MAT8 entry referenced in field 2. The value in a particular field of the MAT8 entry is replaced (if TABLEM1 or TABLEG is used) or modified (if TABLEM2/3/4 is used) by the table referenced in the corresponding field of this entry. In the example shown, E1 is modified by TABLEMi 32; A1 is modified by TABLEMi 15; and Xt is modified by TABLEMi 52. Blank or zero entries mean that there is no temperature dependence of the fields on the MAT8 entry.
- The MATT8 entries may refer to blank entries on the respective MAT8 card. In which case, they will be applied to default values of respective parameters.
- The TEMPERATURE Subcase Information Entry (with type=MATERIAL) is required to activate temperature-dependent material behavior and to define the temperature field (option=SID of TEMP, TEMPD or the SUBCASE ID of a thermal analysis subcase).
- With TABLEM1 or TABLEG, the respective field on MAT8 will be replaced by the table data on MATT8. With TABLEM2/3/4, the respective field of MAT8 will be modified by the table data.
- This card is represented as a material in HyperMesh.
