SECSET
Bulk Data Entry Defines free boundary degrees-of-freedom for One-Step Superelement Analysis.
SECSET | SEID | G1 | C1 | G2 | C2 | G3 | C3 |
SECSET | 11 | 23 | 6 | 8 | 12 | 511 | 33 |
SEID | Superelement identification number No default (Integer ≥ 0) |
Gi | Grid or Scalar Point identification
numbers Default = Blank (Integer > 0) |
Ci | Component numbers (Integer zero or blank for scalar points, or up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks for grid points. The components refer to the coordinate system referenced by the grid points) |
- Degrees-of-freedom on SECSET entry are used to define the boundary degrees-of-freedom which are to be free (C-Set).
