PCONV
Bulk Data Entry Defines a free convection boundary condition properties.
PCONV | PCONID | MID | FORM | EXPF | FTYPE | H1 |
PCONID | Convection property identification
number of a PCONV card. No default (Integer > 0) |
MID | Material property identification
number of MAT4 card. (Integer > 0) Defaults: If FTYPE = 3, Default = Blank If FTYPE ≠ 3, No default |
FORM | Types of formula used for free
convection and, also to define the reference temperature definition for
temperature-dependent convection coefficient lookup. 3 If 0, 10, or 20, If 1, 11, or 21 Where, is grid temperature and is the ambient temperature. Default = 0 (Integer) |
EXPF | Free convection exponent. If FORM = 0, 10, or 20, EXPF = 0.0 for linear convection. If FORM = 1, 11, or 21, EXPF = 1.0 for linear convection. Therefore, linear convection formula is: |
FTYPE | Convection Coefficient definition
type.
No default (Integer) |
H1 | Free Convection Coefficient value (for
FTYPE=3) Defines the Free Convection Coefficient value, if FTYPE=3. No default (Real ≥ 0.0) |
- Every CONV card must refer a PCONV card.
- Heat transfer coefficient (H) is specified on MAT4 card with MID.
- In Nonlinear Heat Transfer, to define the
reference temperature definition for temperature-dependent convection coefficient lookup,
the FORM field can be used as:
- FORM
- Reference Temperature Description
- 0 or 1 (Default)
- Reference Temperature is the average of:
- Element grid point temperatures (average), and
- Ambient point temperatures (average)
- 10 or 11
- Reference temperature is the surface temperature (average of element grid point temperatures)
- 20 or 21
- Reference temperature is the ambient temperature (average of ambient point temperatures).
- This card is represented as a group in HyperMesh.
