RADBC
Bulk Data Entry Defines the radiation boundary conditions and identifies CHBDYE entries for heat transfer analysis via radiation.
RADBC | NODAMB | FAMB | CNTRLND | EID1 | EID2 | EID3 | EID4 | EID5 | |
EID6 | EID7 | etc. |
RADBC | 23 | 0.9 | 334 | 12 | 34 | 33 |
NODAMB | Ambient point for
radiation exchange identification number. No default (Integer > 0) |
between the face and ambient point. No default (Real ≥ 0) |
CNTRLND | Control point for
radiation boundary conditions. Default = 0 (Integer ≥ 0) |
EIDi | CHBDYE element identification number(s).
Keywords THRU and BY are
available for alternate format listing in ascending order of
EIDi. No default (Integer > 0) |
- The effect of
CNTRLND is illustrated as:
If CNTRLND = 0,
If CNTRLND > 0,
- For a Heat Transfer Analysis via Radiation, PARAM,TABS can be used to define the absolute temperature scale, and PARAM,SIGMA is used to specify the Stefan-Boltzmann constant. Additionally, a RADBC entry can be used to define radiation boundary conditions. Both RADM and RADBC entries are referenced on the CHBDYE Bulk Data Entry.
- NODAMB is treated as a black body with its own ambient temperature for radiation exchange between the surface element and space.
