PBEAML
Bulk Data Entry Defines the properties of a beam element by cross-sectional dimensions that are used to create beam elements via the CBEAM entry.
PBEAML | PID | MID | GROUP | TYPE/ NAME |
ND | ||||
DIM1(A) | DIM2(A) | etc | NSM(A) | SO(1) | X(1)/ XB |
DIM1(1) | DIM2(1) | ||
etc | NSM(1) | etc | SO(B) | X(B)/ XB |
DIM1(B) | DIM2(B) | etc | ||
NSM(B) |
* The format of this Bulk Data Entry is somewhat unusual as the field locations can vary depending on the number of dimensions used to define the cross-section.
PBEAML | 99 | 21 | T | ||||||
12. | 14.8 | 2.5 | 26. | NO | 0.4 | 6. | |||
7. | 1.2 | 2.6 | YES | 0.6 | 6. | 7.8 | |||
5.6 | 2.3 | YES |
PID | Unique simple beam property
identification.
No default (Integer > 0 or <String>) |
MID | Material identification. 1
2
GROUP | Indicates if an arbitrary beam section definition is to be used. Refer to Arbitrary Beam Section Definition in the User Guide.
If the value of this field is HYPRBEAM, the following field is
NAME; otherwise it is TYPE. Default = blank (blank or HYPRBEAM) |
TYPE | Cross-section shape. When GROUP field is blank, this field is
TYPE. No default (BAR, BOX, BOX1, CHAN, CHAN1, CHAN2, CROSS, H, HAT, HEXA, I, I1, L, ROD, T, T1, T2, TUBE, or Z) |
NAME | Name
of arbitrary beam section definition. Refer to Arbitrary Beam Section Definition in the User Guide.
When the value of GROUP is HYPRBEAM, this field
is NAME. No default (Character string) |
ND | Number of dimensions used to specify the
Cross-section shape. This is required when the
value of the GROUP field is
HYPRBEAM. ND
represents the total number of dimensions used to
define an Arbitrary Beam Section. Default = blank |
DIMi(A) | Cross-section dimensions at end A. No default (Real > 0.0) |
NSM(A) | Nonstructural mass per unit length at end
A. Default = 0.0 (Real) |
SO(#) | Stress output request option for intermediate
station #. Stress output is not supported for intermediate stations so this field must be set to NO. |
X(#)/XB | Distance from end A to intermediate station # in
the element coordinate system, divided by the
length of the element. Default = 1.0 (Real > 0.0) |
DIMi(#) | Cross-section dimensions at intermediate station
#. (Real > 0.0) |
NSM(#) | Nonstructural mass per unit length at
intermediate station #. Default = 0.0 (Real) |
SO(B) | Stress output request option for end B. Default = YES (YES or NO) |
X(B)/XB | Distance form end A to end B in the element
coordinate system, divided by the length of the
element. This must be 1.0 |
DIMi(B) | Cross-section dimensions at end B. (Real > 0.0) |
NSM(B) | Nonstructural mass per unit length at end
B. Default = 0.0 (Real) |
- For structural problems, MID may reference only a MAT1 material entry. For heat transfer problems, MID may reference only a MAT4 material entry.
- String based labels allow for easier visual identification of properties, including when being referenced by other cards. (For example, the PID field of elements). For more details, refer to String Label Based Input File in the Bulk Data Input File.
- Up to eleven stations are allowed (end A and B, and nine intermediate stations #).
- The cross-sectional properties, shear
flexibility factors, and stress recovery points (C, D, E, and F) are computed using the
TYPE and DIMi as shown below. The element
coordinate system is located at the shear center.
- For PBEAML entries with more than one section, an equivalent PBEAM entry is derived. An echo request will cause a printout of the derived PBEAM.
- Stress recovery is only allowed at end A and end B. Stress recovery at intermediate stations is not supported.
- For TYPE=ROD, if X(1)/XB is equal to 1.0, then the DIM(1)A references the radius of the beam at end A and DIM(1)B references the radius of the beam at end B and there are no intermediate stations. This element is a tapered beam formulation, and averaging is not used to determine the average radius of the beam. Instead, the true tapered beam formulation is used with the given dimensions. The true tapered beam formulation is only available for TYPE=ROD.
- DIMi and NSM have to be specified fully on station A. On station B, blank means that the dimensions are the same as at A. On other stations, it is a linear interpolation between A and B.
- The NSM specified at end A is
the default value for NSM at end B. The default for all other stations
is a linear interpolation between end A and end B. So, for a constant
NSM over the length of the beam, only NSM at end A
is required.The mass of the element is calculated as:
(1) If the NSM value is different in different stations, it is averaged over all the stations and the average is used in the element calculation.
- This card is represented as a property in HyperMesh.
