MBFRCC
Bulk Data Entry Defines a curve force at a grid point by specifying a vector.
MBFRCC | SID | G1 | CID | CVID | G3/N1 | N2 | N3 | G2 | |
INT | EID | G4 |
MBFRCC | 3 | 345 | 9 | 0.0 | 1.0 | 0.0 | |||
AKIMA | 41 | 201 |
SID | Load set identification number. No default (Integer > 0) |
G1 | Grid point identification number where
the action force is applied. No default (Integer > 0) |
CID | Coordinate system identification number.
Blank or 0 infer the basic coordinate system. Default = 0 (Integer ≥ 0, or blank) |
CVID | Set identification number of the
MBCRV entry that gives the load vs. independent variable
measured in the coordinate system defined by CID. (Integer > 0) |
G3 | Grid point identification number to
optionally supply N1, N2,
N3 in conjunction with G1. (Integer > 0) |
N1, N2, N3 | Defines the direction of the force
vector. At least one of the vector components must be non-zero. Default = 0.0 (Real) |
G2 | Grid point identification number where
the reaction force is applied. If blank or zero, the force is an action-only
force. Default = 0 (Integer ≥ 0) |
INT | Interpolation type.
(Character) |
EID | Set identification number of the MBVAR for the independent variable
expression. Default = TIME (Integer ≥ 0 or blank) |
G4 | Grid point identification number whose
parent body hosts the coordinate system with respect to which the force is defined.
The force vector changes direction with the orientation of the body. If undefined, the force is defined with respect to the ground body (that is the basic coordinate systems). Default = blank (Integer ≥ 0 or blank) |
- This card is represented as a force load in HyperMesh.
