PSHELLX
Bulk Data Entry Defines additional SHELL properties for geometric nonlinear analysis.
PSHELLX | PID | ISHELL | ISH3N | ISMSTR | NIP | HM | HF | HR | |
DM | DN | ITHICK | IPLAS |
PSHELL | 73 | 7 | 1.0 | 7 | 7 | ||||
PSHELLX | 73 | 24 | 5 |
PID | Property ID of the associated
PSHELL. 1 No default (Integer > 0) |
ISHELL | CQUAD4 element formulation flag. Default as defined by
XSHLPRM (Integer)
ISH3N | CTRIA3 element formulation flag. Default as defined by
XSHLPRM (Integer)
ISMSTR | Shell small strain formulation flag. Default as defined by XSHLPRM (Integer)
NIP | Number of integration points through the thickness.
Default as defined by XSHLPRM (0 ≤ Integer ≤ 10) |
HM | Shell membrane hourglass coefficient (ISHELL=123, and
4 only). Default = 0.01 (Real, 0.0 ≤ HM ≤ 0.05) Except ISHELL=3: Default = 0.1 (Real) |
HF | Shell out of plane hourglass coefficient (ISHELL=1, 2, 3, and
4 only). Default = 0.01 (0.0 ≤ Real ≤ 0.05) |
HR | Shell rotation hourglass coefficient (ISHELL=1, 2, 3, and
4 only). Default = 0.01 (0.0 ≤ Real ≤ 0.05) Except ISHELL=3: Default = 0.1 (Real) |
DM | Shell membrane damping (with MATX27 and MATX36
only). Default: 7(Real) |
DN | Shell numerical damping (ISHELL=12, 24, ISH3N=30 only). Default: 8 (Real) |
ITHICK | Shell resultant stresses calculation flag. Default as defined by
XSHLPRM (CONST or VAR)
IPLAS | Shell plane stress plasticity flag (with MATX2,
MATX27, and MATX36 only). Default as
defined by XSHLPRM (RAD or
NEWT)
- The property identification number must be that of an existing PSHELL Bulk Data Entry. Only one PSHELLX property extension can be associated with a particular PSHELL.
- PSHELLX is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS=EXPDYN. It is ignored for all other subcases.
- Q4: Original 4 node OptiStruct shell with hourglass perturbation
stabilization.
QEPH: Formulation with physical hourglass stabilization for general use.
QBAT: Modified BATOZ Q4g 24 shell with 4 Gauss integration points and reduced integration for in-plane shear. No hourglass control is needed for this shell.
DKT18: BATOZ DKT18thin shell with 3 Hammer integration points.
- If the small strain option (ISMSTR) is set to 1 or 3, engineering strain and stress are used; otherwise they are true strain and stress.
- For MATX2, the default value for IPLAS and global integration (NIP=0) is IPLAS=RAD.
- For MATS1, MATX36 the default value for IPLAS and global integration (NIP=0) is IPLAS=NEWT.
- Defaults for DM:
Material Element Type ISHELL/ISH3N Default MATX27 except QEPH, QBAT except 12, 24 5% QEPH 24 1.5% QBAT 12 0% MATX36 except QEPH except 24 0% QEPH 24 1.5% - Defaults for DN:
Element Type ISHELL/ISH3N Default Usage QBAT 12 0.1% All stress terms, except transverse shear. QEPH 24 1.5% Hourglass stress. DKT18 12/30 0.01% Membrane stress only. - This card is represented as an extension to a PSHELL property in HyperMesh.
