PAABSF
Bulk Data Entry Defines the properties of the fluid acoustic absorber element.
PAABSF | PID | TZREID | TSIMID | S | A | B | K | RHOC |
PAABSF | 4 | 3 | 4 | 1.0 | 0.5 |
PID | Property identification
number. (Integer > 0) |
TZREID | TABLEDi entry
identification number that defines the resistance as a function of frequency. The
real part of the impedance. (Integer > 0 or Blank) |
TZIMID | TABLEDi entry
identification number that defines the reactance as a function of frequency. The
imaginary part of impedance. (Integer > 0 or Blank) |
S | Impedance scale factor. Default = 1.0 (Real) |
A | Area factor when 1 or 2 grid points are
specified in the CAABSF entry. Default = 1.0 (Real > 0.0) |
B | Equivalent damping
coefficient. Default = 0.0 (Real) |
K | Equivalent stiffness
RHOC | Constant used in data recovery for
calculating an absorption coefficient.
Default = 1.0; current unused (Real) |
- PAABSF is referenced by a CAABSF entry only.
- If only one grid point is specified on the CAABSF entry, the impedance Z(f)=ZR+iZi is the total impedance at the point. If two grids are specified, then the impedance is the impedance per unit length. If three or four points are specified, then the impedance is the impedance per unit area. ZR(f)=TZREID(f)+B and Zi(f)=TZIMID(f)=K/(ω) .
- The
resistance represents a damper quantity B. The reactance represents a
quantity of the type
(ωM−K/ω)
. The impedance is defined as:
(1) Z=p/uWhere,- p
- Pressure
- u
- Velocity
- The
impedance scale factor S is
used in computing element stiffness and damping
terms as:
(2) k=AS2πfZi(f)S2R+Z2i∫(of shape functions)b=AS2πfZR(f)Z2R+Z2i∫(of shape functions) - To
create a non-reflecting boundary, set the values of the TABLEDi entry
referenced by the TZREID field (Resistance-real part of Impedance) to be
equal to (
ρ
fluid) * (cfluid) for all frequencies. This will
allow the acoustic wave to propagate normally through the boundary, without reflection. This
condition is called the Sommerfeld boundary condition.Where,
- ρ fluid
- Density of the fluid
- cfluid
- Speed of sound in the fluid
- This card is represented as a property in HyperMesh.
