Processing math: 100%
DVMBRL1
Bulk Data Entry Linearly relates a design variable to properties of an MBD entity using the equation: Pi=C0+COEFi*DVIDi
DVMBRL1 ID TYPE BID/
EID
PNAME     C0
  DVID1 COEF1 DVID2 COEF2 etc.
Example 1
To relate the translational x component of stiffness value (K1) on a CMBUSH whose ID is 22 to Design Variable 5.
DVMBRL1 88 CMBUSH 22 K1     0.0
  5 1.0
DESVAR 5 5.00 1.50 9.90
Example 2
To relate the mass of a rigid boy whose ID is 3 to design variable 5.
DVMBRL1 88 PRBODY 3 M     0.0
  5 1.0
ID Response identity. ID must be unique with respect to other DVMBRL1 and DVMBRL2 cards.
No default (Integer > 0)
TYPE MBD entity type to be related. 1
No default (Character)
BID/EID Body ID or Element ID number. When TYPE is PRBODY, this field is the ID number of a rigid body. When TYPE is CMBUSH(M), CMBEAM(M), or CMSPDP(m), this field is the ID number of a corresponding element.
PNAME Property name, such as "A" or "L" (as in the documentation of the PRBODY, CMBEAM(M), CMBUSH(M), and CMSPDP(M) cards).
No default (Character or Integer > 0)
C0 Constant in relationship equation.
Default = 0.0 (Real)
DVIDi DESVAR ID.
COEFi Coefficient in relationship equation.
Default = 1.0 (Real)
  1. MBD entity type information:
    PRBODY
    IXX
    IYY
    IZZ
    IXY
    IXZ
    X
    X component of center of gravity.
    Y
    Y component of center of gravity.
    Z
    Z component of center of gravity.
    CMBEAM/CMBEAMM
    L
    Undeformed length along the X-axis of the beam.
    A
    Area of the beam cross-section.
    I1
    Area moment of inertia in plane 1 about the neutral axis.
    I2
    J
    Torsional constant.
    K1 ~ K2
    Area factor for shear.
    CMBUSH/CMBUSHM
    K1 ~ K3
    Translational stiffness.
    K4 ~ K6
    Rotational stiffness.
    B1 ~ B3
    Translational damping.
    B4 ~ B6
    Rotational damping.
    P1 ~ P3
    Translational preload.
    P4 ~ P6
    Rotational preload.
    CMSPDP/CMSPDPM
    K
    Stiffness
    B
    Damping
    L
    Unstretched length of spring damper.
    PF
    Preload force.
  2. This card is represented as an optimization design variable property relationship in HyperMesh.
