INVELJ
Bulk Data Entry Defines initial velocity of a joint in a multibody situation.
INVELJ | SID | JID | JTYPE | VT | VR |
INVELJ | 1 | 3 | REV | 10.0 |
SID | Load set identification
number. (Integer > 0) |
JID | Joint identification
JTYPE | Joint type.
No default |
VT | Translational
velocity Real, when JTYPE = TRANS |
VR | Rotational
velocity Real, when JTYPE = REV |
