HYBDAMP
Bulk Data Entry This Bulk Data Entry defines the application of modal damping to the residual structure in a Direct Transient or Frequency Response analysis.
HYBDAMP | SID | METHOD | SDAMP | KDAMP |
HYBDAMP | Keyword for applying modal damping on a direct analysis | |
SID | Unique hybrid damping SID (Refer to HYBDAMP I/O Option). | |
METHOD | EIGRL/EIGRA data
identification number. Hybrid damping is applied on the modes
determined by the eigenvalue analysis. No default (Integer > 0) |
SDAMP | A TABDMP1 entry identification
number for modal damping. No default (Integer > 0) |
KDAMP |
(Integer) |
- HYBDAMP/SID can be set by the HYBDAMP I/O Options Entry in the I/O section of the input data.
- Hybrid damping can be defined as: If KDAMP is set to 1/NO (Default), then:
(1) If KDAMP is set to -1/YES, then:(2) Where,- i
- Modes of the structure
- [M]
- Structural mass matrix
- b( i)
- Modal damping values (b( i) = g( i) imi)
- b( i)
- Are equal to twice the critical damping ratios calculated from the TABDMP1 entry
- i
- Natural frequency of mode i
- mi
- Generalized mass of mode i
