PELASFX
Bulk Data Entry Used to define the stiffness and stress coefficient of a scalar elastic element (spring) by means of the CELAS1 or CELAS3 entry.
This property is not affected by translational and rotational stiffness limits specified using PARAM,ELASSTIF.
PELASFX | PID | K | GE | S | PID | K | GE | S |
PELASFX | 7 | 4.29 | 7.92 | 27 | 2.17 |
PID | Unique scalar elastic property identification
number. No default (Integer > 0) |
K | Elastic property value. No default (Real) |
GE | Damping coefficient. To obtain the damping coefficient GE,
multiply the critical damping ratio,
, by 2. GE is ignored in transient analysis, if PARAM, W4 is not specified. Default = 0.0 (Real) |
S | Stress coefficient. Default = 0.0 (Real) |
- Be careful using negative spring values.
- One or two elastic spring properties may be defined on a single entry.
- The
element force of a spring is calculated from the equation:
F = k * (u1 - u2)
Where, k is the stiffness coefficient for the scalar element and u1 is the displacement of the first degree-of-freedom listed on the CELAS entry. Element stresses are calculated from the equation: s = S * F, where, S is the stress coefficient as defined above.
- This card is represented as a property in HyperMesh.
