TABLEMD
Bulk Data Entry Defines a multi-dimensional tabular function which identifies single or multiple X-values for a single Y-value.
Format (NDEP ≤ 7)
TABLEMD TID NDEP
  Y1 X1_1 X1_2 X1_3 etc etc etc X1_7
  Y2 X2_1 X2_2 X2_3 etc etc etc X2_7
Format (NDEP > 7)
TABLEMD TID NDEP
  Y1 X1_1 X1_2 X1_3 X1_4 X1_5 X1_6 X1_7
    X1_8 etc etc etc X1_ndep
  Y2 X2_1 X2_2 X2_3 X2_4 X2_5 X2_6 X2_7
    X2_8 etc etc etc X2_ndep
TABLEMD 32 6
  -3.0 6.9 2.0 5.6 3.0 5.6
TID Table identification number.
No default (Integer > 0)
NDEP Identifies the number of dependencies.
Yi Yi values.
No default (Real or ENDT)
Xi_i Xi values for each corresponding Yi value.
  1. At least one continuation entry must be specified.
  2. When TABLEMD is used in OSTTS damage calculations, NDEP=1 should be specified. The Xi_j values should be specified in ascending order only.
