generic
Unless otherwise specified, data names are accessible in level 3 only.
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
collector
Pointer to the collector that owns the element.
Type: pointer (levels 2, 3 and 4)
config
The configuration of the entity.
Fillcolor
The color the beam section uses for display of solid regions.
Type: integer
Flags
The optimization flag.
Type: integer
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
Linecolor
The color the beam section uses for display of lines.
Type: integer
name
The name of the entity.
Type: string
OrientationOrigin0
The y component of the beam section origin.
Type: double
OrientationOrigin1
The z component of the beam section origin.
Type: double
OrientationVector0
The y component of the beam section orientation vector.
Type: double
OrientationVector1
The z component of the beam section orientation vector.
Type: double
setid
The ID of the beam section collector owning the entity.
Type: integer
TorsionFactor
The torsion factor of the beam section.
Type: double
WarpingFactor
The warping factor of the beam section.
Type: double
