DOPTPRM, MINDIM
Bulk Data Entry Specifies the minimum diameter of members formed in a topology optimization.
Parameter | Values | Description |
MINDIM | Real > 0.0 Default = no minimum member size control |
This command is used to eliminate small members. |
