PARAM, ELASSTIF
Bulk Data Entry Specifies a value to replace large stiffness values (>1.0E+07) input in field K of the PELAS Bulk Data Entry. This parameter can accept two arguments. If only one argument is specified, the same value is used for the second argument.
PARAM, ELASSTIF, <ELASSTIFT>, <ELASSTIFR>
Parameter Values Description
ELASSTIFT <Real Number ≥ 0.0>
No default
This parameter controls the value of field K in the PELAS scalar elastic property entry and the CELAS2/CELAS4 scalar spring property and connection entries.
ELASSTIFT
This value applies to translational stiffness fields on the PELAS scalar elastic property entry and the CELAS2/CELAS4 scalar spring property and connection entries.
ELASSTIFR
This value applies to rotational stiffness values on the PELAS scalar elastic property entry and the CELAS2/CELAS4 scalar spring property and connection entries.
ELASSTIFR <Real Number ≥ 0.0>
Default = <ELASSTIFT>
  1. Any value on the field K on the PELAS or CELAS2/CELAS4 entry which exceeds ELASSTIFT or ELASSTIFR, respectively will be replaced by ELASSTIFT or ELASSTIFR.
  2. Either ELASSTIFT or ELASSTIFR (or both) can be set to 0.0. This will disable stiffness control for the corresponding translational or rotational stiffnesses.
  3. Defaults:
    • If ELASSTIFT is input without specifying a value, then OptiStruct will error out (no default). The default for ELASSTIFR is ELASSTIFT.
    • If PARAM, BUSHSTIF is not included in the deck, the elastic property value (Field K) is not replaced regardless of its value (no stiffness control).
  4. This parameter cannot be used to modify the values specified on CELAS2F, CELAS4F, or PELASFX Bulk Data Entries.
