PARAM, SBTOLRTR
Bulk Data Entry Used to modify the tolerance value for symmetric beams when they are used for rotor modeling.
Parameter | Values | Description |
SBTOLRTR | <Real > 0.0> Default = 1.0E-6 if parameter is not present in the model. |
The tolerance value (
val
) is used in the following checks:
