ic
Unless otherwise specified, data names are accessible in level 3 only.
- attributesmax
- The number of attributes owned by this entity.
- collector
- Pointer to the collector that owns the element.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- dependentdofs
- The dependent node degrees of freedom, consisting of the values 1-6.
- dependentdofsmax
- The number of dependent degrees of freedom for a given independent node.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- independentnodes
- Pointer to the independent nodes.
- independentnodesmax
- The total number of independent nodes.
- nodecount
- The number of nodes for the element. Valid for hm_getvalue query only.
- nodes
- The list of nodes for the element. Valid for hm_getvalue query only.
- type
- The solver dependent type code for the entity.
- typename
- The solver dependent type name for the entity.
